Drain and Replace Fluid in hydraulic shuttle
KubotaL185DT
L185 4x4, L245H, M5140HD, Case 580B Hoe, JD350 Dozer, JD LX178,
May 6, 2010
81
Northern Calif
Is there any tricks to shorten the time to warm up the hydraulic fluids on a M5140 with hydraulic shuttle tranny?
5,298
With Bulldog on this one... What's happening or not happening with it?
4,883
1,617
If you're just draining & refilling, and warming the fluid to make it go a little faster, use the loader valve to dead-head pressure for a few seconds, and it'll warm the oil faster. I never do it as it's hard on the pump done for any length of time; with super UDT and even regular UDT, I'll loosen the hydraulic filter with a bucket under it, let it drain out, then go under the tractor and do the rest. Doesn't take long. BUT if the wrong fluid is used (cheap TSC stuff for example), it can take forever to get the fluid flowing....which can also lead to weak/no hydraulic functions until the tractor's been run a little bit.
