Hello, I recently purchased a 9540 and will be doing a lot of Slashing with it using a 3pl PTO slasher. Was reading the owners manual and are a bit confused. Would I put the PTO draft control and position levers fully down in the float position so it follows the ground contours better. Most info on the net is for draft control when you are plowing. regards Bob
First:
It's not the PTO draft control, PTO (power take off) is the spinning shaft out the back.
It's the three point lift that is controlled by the draft and position control.
And like others said no you don't use the draft control for slashing.
Draft control is used to keep a ground engaging implement from pulling down on the three point and allowing, say a plow, go too deep.
With a brush hog / slasher, you set the rear wheel and the top link and the positional height of the three point to control the height of the cut.
