Down-Hill In A Hurry
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Mine is always in 4WD here due to use case and lots of slope. Only use diff lock in "monsoon season" where I really should call it a day anyway
Have accidentally taken similar exciting rides in my 2WD f@rd with turf tires a lot more than I care to admit... :eek:
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,384
1,007
Minnesota
Bet your shorts were full after that scary ride. When in doubt, put it in 4 wheel drive. I rarely use the rear differential lock.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
It wasn't bad; concerning, but kind of fun the first time (I used to race, though not in reverse). It was not so much fun I wanted to do it a second time, especially given the garage wall had a workbench and truck on the other side. Thankfully I'd learned from the first slip-n-slide to put my hand strictly under the loader control so there was no thinking involved, just "Push In Case Of Emergency"--that saved my bacon, and who doesn't love bacon? The next rock relocation will involve using 4WD, diff-lock, and a counterweight--no more short-cutting.
I should probably also mention the Deadman Switch Bypass Project hasn't been finished, so if I were separated from the seat the engine wouldn't kill, and that was concerning. The jumper wire some members use as a permanent solution needs to be replaced by the actual switch modification so the bypass is active only when needed.
wicknwobin
BX24
Jun 8, 2025
Grants Pass, Oregon
This Memorial weekend I was farming rocks, and while they do move on their own, some needed a bit of help getting from Point A to Point B as they were not destined to head that direction.
Point A is back on a flat at the top of a hill, Point B is mid-way up the hill, and it's a pretty steep hill.
I didn't have the weight bucket out back because...it was just a few rocks.
Well, I had a fatty (rock, not that fatty) and was headed down the hill in reverse at a snail's pace to the point I think a snail did actually pass me up. And the tractor got a bit off perfectly-straight-up-and-down-vertical, not much, but enough to lift one rear wheel a little. Now, little did I know, but the BX I own does not have a locking differential, so once one tire was off the ground I was rocketing down the hill, in reverse, with obstructions like rocks and trees and a turn at the bottom--at light speed--so fast I didn't have time to look where I was headed and had to steer from memory. In reverse. (I almost had a new racing stripe, not on the tractor itself.)
Thinking about it in hindsight, there is a pedal to lock the differential, which being Spring and not having used the diff-lock since last year I'd completely forgotten about. I also had on turf tires, because...I was on turf.
After that incident I was definitely just as cautious going down "the other, steeper hill," however facing forward. I had a much lighter load than "fat Gertrude" and figured I was fine.
Well, guess how that went.
Same situation, one tire lost traction and I was heading downhill toward the side of the garage at light speed, so fast bugs were spattering on my eyeballs as if it were a car windshield. I don't know if you know this, but I didn't know it: the brakes affect only the rear wheels. So here I am mashing the brake pedal without any effect other that looking a bit more...uh, "puzzled." However, this time I couldn't "ride it out" because the roller-coaster was headed right for a building. BAM! Dropped the bucket and between the friction of the bucket and the braking force of the rear wheels now firmly planted on the ground everything came to a halt, other than some of what was in the bucket which continued on another few feet. (No rocks required medical attention.) However, everything stopped short of the garage, so all good there.
LESSON: Put your tractor in four-wheel-drive when on hills with a load. It's that simple. I think. I haven't tried it yet.
