Does Pump Diesel Contain Additives?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,749
2,195
Western MT
Jimh406: Your sarcastic/angry/nasty/demeaning responses are inappropriate for this very pleasurable forum.
No, quoting someone and not wanting a response when you were wrong is inappropriate.
On the other hand, maybe you'd feel better if you use the ignore feature. Up to you.
5,185
It is not all about ME, .......it is about respect, or lack thereof, for everyone on this forum!
Sdatrucking
B7100.
Aug 26, 2022
58
20
Tagalong3746
I drive otr usually add additives once monthly had algae prob once and it was a nightmare also when using a good additive I can increase fuel mileage sometimes as much as 1 mile per gallon on a tractor not much savings but on a semi running 5 to 6 thousand miles a week makes a huge difference I prefer Howes or Lucas just my 2 cents been doin this over 30 years
7,262
Have a friend who drove OTR and he purchased Lucas in gallons by the case. He was convinced it improved his MPG on his big rig.
10,079
There are endless tests and comparisons showing that diesel additives can make an appreciable difference to engine and fuel system performance and longevity, so anyone saying that it's "purely subjective/opinion" is either ignorant or disingenuous. I will continue to use Stanadyne in my five diesels as I have for over 30 years.
will721
LX2610, Ford 2n, Ferguson TO20
Jun 6, 2023
179
187
Quad Cities Area
Former diesel tech, general tinkerer, and someone who drives a diesel daily: it depends.
Good quality fuel from a station in newer equipment needs nothing generally. It isn't a bad idea to run an additive in newer common rail equipment to add lubricant to the fuel due to the extreme pressure and multi-pulse injection but its not required. In those applications the main enemy is contamination. A good cetane booster can be beneficial as well but again isn't necessary. I'm currently upgradinf the fuel system on my truck due to an early injector failure most likely due to bad quality fuel but couldn't exactly empty on the side of the road.
Biodiesel is different. If allowed to sit it can self contaminate by growing microbes or algae. It is good practice that if you store it or if you run it in a vehicle that doesn't replenish fuel often to run additives that keep the growth out. This is especially true if the fuel system is not air tight, or is prone to organic matter getting in like grass clippings.
Older diesels benefit the most from additives, because they were designed with a virtually different fuel in mind. They need added lubrication for the injection pumps. They also benefit much more from cetane boosters. But mostly its the added lubricant, shortening the life span of the injection pump.
I'm not a kubota tech and obviously do not know their entire engine line up so choosing to run additive may vary. However on my LX, and with every kubota diesel I've come across thus far which are all low hp at work, they are not high pressure and are designed to run on modern fuel so I don't see a benefit other than mabey an antigel in winter. I do run additive in mine, but only because my fuel tank is shared. The first two tanks were untreated and I experienced zero benefit to cetane booster.
Someone mentioned a marine application, I know for marine fuels similar to aircraft they don't necessarily meet thr same standards if you are fueling on the water. But I can't say for sure if they are using ultra low sulfer diesel or not. Does it say at the pump?
NorthwoodsLife
Oct 15, 2021
1,411
1,471
Wisconsin
If it gets mighty cold where you and your tractor are, take note that in cold climates pump diesel IS definitely seasonal.
My neighbors rarely used L3301 quit running this past winter. It was close to 20 degrees below zero Fahrenheit. Below zero daily. He was using summer-time bought diesel. We put in some diesel fuel winterizing additive and let it sit a couple days. And his L3301 ran like a top.
You've gotta winterize your diesel fuel in the really cold areas. In the winter, the gas stations in the area do it. But I still add more.
