Do R4 tires suck in snow?
SDT
Apr 15, 2018
3,705
1,425
In a word, YES in fact theR4s are skidsteer tires I dont know the brain truss that thought putting skid steer tires on a tractor was but I hope his nutz fall off! The old R4 tires on my BX are out standing, on the B they suck!!!
R4s (so-called industrial tires) are designed to slip.
This is a desireable feature on industrial equipment, e.g., industrial TLBs, to prevent digging holes when pushing the bucket into a pile of dirt. R4 tires are not intended for AG work and no tractor tires are designed for snow removal.
nbryan
Jan 3, 2019
1,437
950
Hadashville, Manitoba, Canada
R4's here for my 8th winter, so I know pretty well by now how my particular rig handles for traction in widely varying snow blowing conditions. They slip sideways fairly easily in a certain near freezing conditions so I just slow it down and maybe stay off the driveway shoulders until things freeze up proper.
But it usually gets very cold after snowstorms around here, and the R4s are just fine to quite amazing at handling snow and ice. They're not only snowblow season tires, either. Their year-round load handling capabilities are impressive, and they do well in mud, gravel, sand...
I like my R4s for how they've handled 9 years, 1400 hours, sometimes abusive treatment, and our Manitoba climate.
Grandad4
Apr 5, 2016
446
195
Greensboro, NC
No fluid in the tires on the BX. But I do keep the box blade attached when using the FEL bucket or grapple claw. Need the weight for ballast and probably improving rear tire traction. Occasionally on the steeper pitches of the driveway under really slippery conditions the snow blower is lifted off float to add some traction mass to the rear wheels that have chains on.
Wondering how many pounds of weight fluid would add to the front tires? They are tiny at 18-8.5 x 10s. Unsure of the mass of the LA344 loader and bucket. They stay on during snow blowing season. Guessing fluid in the fronts would not be significant relative to loader and bucket weight.
I added fluid to the rear tires on the BX we had and it improved balance and traction just like more rear weight did for the Grand L. About 110 lbs of blue window washer fluid if I remember correctly. Juice in the fronts wouldn't amount to much but there are mounting holes for attaching weights on the front. The factory weights are probably expensive but a DIY job would work just as well.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
472
268
Randolph county N.C.
I have had my tractor for five years and have not plowed snow with it. Our first storm dropped 3" of sleet and was really easy to clean up with good traction. We had a storm a few days ago that dropped 8" of snow. This was my first time plowing snow with my 4760 using a 7' scrape blade. Traction was horrible with my rear tires at 14 psi, front tires at 24 psi. Dropped pressure to 10 psi rear and 20 psi front. I get around better but still not great. I just gotta remember to air up before doing any heavy lifting with the loader.
blacktop
Grand L4060
Aug 8, 2025
10
30
Ontario Canda eh
I have the nokian hakkapeliitta. they are a snow tire and have excellent grip. Expensive but worth it for me in Canada
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,524
554
R4's are all I ever used in all snow conditions and on hills. There are better winter tires, but if you have throttle control, I have no issues.
If you are the type that just mashes the pedal at full throttle, you are going to say they suck.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,396
1,013
Minnesota
Have learned to back off the throttle when I start spinning. Even back up a little, then move on.
