Dividing Up A Long Piece Of Chain
SkylineAcres16
Kubota MX5800 HST, International B-275 Diesel
Sep 3, 2016
40
I had a continuous 63' piece of 1/4" G43 chain given to me and I am wondering how you guys would divide it up for general chores around the property? Disclaimer, I know 1/4" is light (2600 lb working load) but I already have plenty of 3/8" chain for the big stuff. This would be more like lifting a motor, an implement out of the weeds, etc.
I have already cut (2) 10' pieces from the original 63' so I am down to 43' but I am nervous to cut more because I don't want to end up with lengths I don't use much of. I was thinking a few 4-6 footers? Seems like short ones come in handy. I was also thinking a 20' but don't know how practical that would be with a 1/4" chain.
Tooljunkie
May 13, 2014
4,150
27
1-3' 4-10'
Remember it was free. I have a couple 2 footers in my toolbox for various purposes. Wrap a chain around lower control arm for seperating ball joints to swap axles. Short one in tractor toolbox to fasten/load drag something.
jimbo913
L5030 with cab and HST
Apr 22, 2011
89
PA
Dont cut the rest until you need it and then you will know what you need without guessing
bcp
BX2360
Apr 20, 2011
645
77
SW WA
I have a 1/4 inch bucket chain system. From the center, I hang a short chain with a swivel hook. A clevis goes in the hook. It has 4 short (maybe 6in) chains with grab hooks.
Then I have four 4-5ft chains with a grab hook on one end. I hook these chains around the thing to be moved. Then lower the bucket hooks over the thing and hook the 4ft chains into the hanging grab hooks. This allows a little more versatility than having the 4ft chains permanently fastened at the top end.
And I have a half dozen other chain lengths available. Most used are a couple of 12ft 1/4 inch grade 70 I keep on the tractor. They are usually too long for a job, but are there if needed. Easy to make a chain shorter.* Hard to make it longer.
*Hook two grab hooks back-to-back with a link or two between.
Bruce
2,240
I love short pieces of chain with grab hooks on both ends. I'm always rigging something to lift it, pull it out, or tie it down, and short chains are always handy.
If I had to guess, I probably have
(3) 20'-30' 3/8"
(1) 10' 3/8"
(1) 3' 3/8"
(2) 2' 5/16"
(3) 10' 1/4"
(3) 6' 1/4"
(3) 2' 1/4"
Plus another half a dozen pieces in various sizes & lengths without hooks.
I like chain.
2,860
Put hooks on both ends and leave it alone,,, you can make it any length you what to then, it sucks when you need a long chain and only have a bucket full of short ones,,, dont ask
NoJacketRequired
May 25, 2016
415
Ottawa, Ontario
One of the most useful chains I have is about 25 feet long. Three feet from one end another three foot piece has been added on to form a "Y". Grab hooks are on all three chain ends. I initially thought this was a stoopid thing to have. Now it's my "go to" chain because it can do so many things so quickly.
dandeman
BX2230, LA211 FEL, RCK60B Mower, GCK60BX Bagger; Ford 4000, bush hog, blade, etc
Aug 9, 2013
166
Chapel Hill, NC
www.dan-de-man.net
My chains were acquired over time, the smallest being 5/16" and some are 3/8" and 1/2" lengths all around 20' long and with hooks.. and add up to around 100 feet.
I keep them on a steel bar carrier that's on the back of the tractor to add additional weight as a counter weight for the FEL.
Very handy there..
BWXT
'83 B5100D
Personally I would just cut pieces as I needed it. I have a 100' bucket of 3/8" in the garage. That being said, I've found that for vehicle recovery the longest pieces come in handy and 6-10' sections for pretty much everything else. I wouldn't be too trigger-happy on the cut-off wheel until you need it for something.
