Ditch cleaning help
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
I have similar ditches on my 0.6mi gravel driveway. While a seated-on-tractor solution would be plush... I can't find a viable solution at a reasonable cost.
I just walk with my high powered backpack blower and the hike up the driveway gets all the leaves and sticks out of the ditch and halfway across gravel. And then the return walk back down the driveway blows at all over into the woods on the other side.
I have to do this 3-4 times after the leaves fall to prevent the leaves and sticks from forming dams that divert the deluge of water runoff out into the gravel driveway where it erodes gullies. Its a situation where the ounce of prevention is definitely worth the pound of cure.
I don't have a situation like that, but I can still dream of how it can be dealt with:) First thing that came to mind is making a mount to attach my Stihl 800 Magnum to the right end of the snow plow. Maybe extend the "duct" enough to drive on the roadway. With UP/DOWN/RIGHT/LEFT available via joystick and third function I'd probably experiment. Maybe just mount the blower on the forks and do something with an extended duct and linear actuator. I wish this wasn't starting to sound like fun for Fall leaves in the yard. Stay in the cab and out of the dust. It might not take much material that isn't already laying around here somewhere.
g_man
Feb 3, 2023
407
1,902
NE Vermont
How about a back-pack blower. I see state park guys using them. They blow out the trench and then clean up the road with a rake or blow the leaves across. Not sure what they use but they sound very powerful and blow sticks and small stones as well as leaves.
gg
MOlivin
L6060
May 15, 2023
78
17
MO
What backpack blower are you using?
Was trying to not blow anything onto the nice while gravel geocell once thats placed on the driveway. I can see that blowing gravel out of the cell and off the side along with the leafs and twigs. But the only thing ive found so far are 2 types of PTO Vac machines +/- $5k.
