Discontinued part,
furbody
B2150
Nov 2, 2019
Mtn home ar 72635
Hello,
I’m looking for a rear fork shifter, part #67176-18130 for a kubota b2150d, I’m being told it’s discontinued, anybody have any suggestions
5,066
Hello,
Who told you it is "discontinued"
Have you talked with Messick's parts dept?
Sometimes Messick's can/will suggest an alternate source for new or used parts.
whitetiger
Nov 20, 2011
2,917
1,378
Kansas City, KS
Hello,
That part has been discontinued for several years and was only used in the B2150's. You can try salvage yards, but your best bet is to take the failed fork to a good machine shop for repair.
4,892
wt is correct, any good shop can either repair or make a new one.
If the 'fingers' are just worn, easy to add material, grind to 'as new'.
you could try googling the part number, see if anyone has it as 'dead stock', though discoed for years... unlikey.
5,526
Most shifting forks wear on the flat surface where engagement takes place. Use a wire welder to build up that area and dress it smooth.
3,314
Yep…we are a “replacement“ society. Any good blacksmith could fix it. 😜
SDT
multiple and various
Apr 15, 2018
3,248
1,038
SE, IN
Hello,
Have you yet had your dealer search inventory at other dealers?
It's a long shot but sometimes productive.
SDT
katansam
B8200, BF-350 loader, Woods BH750
Oct 18, 2021
50
11
Greene RI
Not sure if this helps, but ive been having luck with "Gernambliss" over Messicks in finding older parts for my B8200. Being a discontinued part may effect your results though. Good luck
