Disconnecting FEL QuickCoupler
Gene Blister
2019 Kubota B2601, FAL LA435, Snow Blower BX2822A, Land Pride rear blade RB1572
Aug 4, 2019
84
20
Cocolalla, Idaho
LA435 QuickTach is coming off to install the K Connect snow blower. The hydraulic quickcoupler won’t come off. Pressure released, red button opened, lever up/forward as far as it will go....Im at the wail on it with a hammer stage, but will try intelligent inquiry to experienced, mature men first. Couldn’t hurt. Any insights or suggestions?
4,470
If you're removing your loader, be sure the loader bucket is on the ground, turn tractor off, then move the joystick in EVERY direction to release pressure. Connection should then not have pressure on them and disconnect.
PaulR
Aug 3, 2020
581
460
Hadley, MA
Got my K-connect yesterday for my snowblower, it's pretty slick. For poops and giggles I tried to get the FEL back on with the K-connect on there, seems it will fit but I cannot get the loader stand out of the way. I started a thread about this but it seems nobody knows if it will work. May keep trying.
My quick-coupler was acting a bit funky too so it seemed, it only locked in after I put it in float position. <shrug> maybe had some residual pressure I forgot about.
