Dipper snapped
selftot
L3400
Aug 6, 2025
31
Vancouver Island
It happened digging out a large rock.
I expect a good welder can fix this but is there a reason not to go that route ?
I know a good welder - this is beyond my skill level.
FYI-The black line on the cylinder is a zip tie.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
267
66
Southern IL
I'm no expert on metal fatigue, but that break seems to have a lot of rust on it. No shiny metal anywhere except where paint is flaking on top side.
selftot
L3400
Aug 6, 2025
31
Vancouver Island
The corner seen in the photo is not nice at all. At the edges on the other corners, the metal looks clean.
Metal fatigue is why i asked the question. The work i was doing was not excessive and I believe this problem had been building over time - just waiting to happen.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,742
2,188
Western MT
I agree with might as well reinforce it while the welder is hooked up.
Nicksacco
Kubota L35 TLB, 2014 RTV-1140CPX
Sep 15, 2021
758
495
Bahama, NC
The break is remarkably straight!
Welding will repair that however I would carefully inspect the interior.
The metal reinforcements should be cut to ensure proper overlap and yet look good once painted.
Goodluck with it.
4,505
Wow, thats quite a "crack"
I agree that a good welder should be able to take care of that.
Hell, I would even attempt it myself.
I would pull it off so I could weld it on a table. Then cut it apart, grind it clean and weld it with some “strategically placed” reinforcement plates.
Thats just me though…….
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,068
1,522
Pittsburgh
It's been slowly failing for some time.
Yooper
3901 LA525
May 31, 2015
1,683
843
NE Wisconsin
Interesting that a stress riser was created at the end of the weld for the gusset plate even though the weld was extended beyond the corner to prevent that! I see no issue with repairing this.
John T
2017 BX23S
May 5, 2017
1,130
625
under a rock
If it's not completely broken in 2 pieces, I'd Vee it out a bit / put a chain or come-along on it and close up the gap and tack weld it back into position first...
THEN take it apart and put it on the bench and fully weld the crack/grind it flush/then fish plate it and weld it up better than new.
Not a difficult job. If you delivered it to me I'd probably charge $500 .... plus the cost of 3/16 or 1/4" plate if I didn't have some hanging around.
