Dipper snapped
selftot
L3400
Aug 6, 2025
116
142
Vancouver Island
It happened digging out a large rock.
I expect a good welder can fix this but is there a reason not to go that route ?
I know a good welder - this is beyond my skill level.
FYI-The black line on the cylinder is a zip tie.
Reactions: 6 users
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Wow, never seen that before, if it was mine, I’d pull it all off and do some heavy horizontal arc welding
L35
Jun 13, 2010
713
831
CT
Impressive!
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
290
91
Southern IL
I'm no expert on metal fatigue, but that break seems to have a lot of rust on it. No shiny metal anywhere except where paint is flaking on top side.
Bee-Positive
Nov 16, 2022
1,152
1,067
Amsterdam, NY
I hate it when my dipper snaps.
What Jay said - plates and weld er up.
selftot
L3400
Aug 6, 2025
116
142
Vancouver Island
The corner seen in the photo is not nice at all. At the edges on the other corners, the metal looks clean.
Metal fatigue is why i asked the question. The work i was doing was not excessive and I believe this problem had been building over time - just waiting to happen.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,977
2,357
Western MT
I agree with might as well reinforce it while the welder is hooked up.
Nicksacco
Sep 15, 2021
770
504
Bahama, NC
The break is remarkably straight!
Welding will repair that however I would carefully inspect the interior.
The metal reinforcements should be cut to ensure proper overlap and yet look good once painted.
Goodluck with it.
5,518
Wow, thats quite a "crack"
I agree that a good welder should be able to take care of that.
Hell, I would even attempt it myself.
I would pull it off so I could weld it on a table. Then cut it apart, grind it clean and weld it with some “strategically placed” reinforcement plates.
Thats just me though…….
Reactions: 6 users
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,219
1,840
Pittsburgh
It's been slowly failing for some time.
Reactions: 6 users
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
Interesting that a stress riser was created at the end of the weld for the gusset plate even though the weld was extended beyond the corner to prevent that! I see no issue with repairing this.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,344
865
under a rock
If it's not completely broken in 2 pieces, I'd Vee it out a bit / put a chain or come-along on it and close up the gap and tack weld it back into position first...
THEN take it apart and put it on the bench and fully weld the crack/grind it flush/then fish plate it and weld it up better than new.
Not a difficult job. If you delivered it to me I'd probably charge $500 .... plus the cost of 3/16 or 1/4" plate if I didn't have some hanging around.
selftot
L3400
Aug 6, 2025
116
142
Vancouver Island
I've been reminding myself today of the times in the past that I trusted the integrity of the backhoe and put myself (or other things) in harms way.
Not so much recently since i learned about the dangers of hydraulics giving out.
But this could have happened in a much more dangerous situation.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
612
638
Lake Almanor, Ca
Soooo….why did that break there?
Almost looks like that metal was made brittle to crack straight like that by the vert weld. Almost looks like the manufacturer drilled a strain relief hole and welded over it on mine and OP. IMG_1389.jpeg
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
561
190
NZ
For speculation, here are some detailed pics.
Really good point @Yooper. IMHO that sort of weld detail is more common on HT steels - real engineers (i.e. not me) may disagree :) - so I'd design the reinforcing and weld process with that in mind.
