BonnySlope
BX2380FEL, Add-A-Grapple, Titan 48" Box scraper, 60" Rake, 72" Rear Blade, Flail
Installed Runleader Rotating shaft hour meter Tachometer (Runleader RL-HM019C) it's reading RPM's and that's all I need it for. The problem I'm having it's displaying to high rpm excess, full throttle 7500 and start up 2800. Trying to go through Amazon to chat with sell Runleader for troubleshooting. Before the instruction sheet got washed Oops I read most of, Max distance setting 5mm (.19)I'm was set at .12 when I got high readings. ,turning unit off (hold) and how it will automatic sense and display RPM or you can toggle threw and get max reading (rpm 2) along with svc(service time), hours and a few others you just have to toggle through and like mention true RPM will display auto.
I just don't recall a trouble shooting session and on Runleader website they have a downloadable instruction sheet BUT it doesn't work. The reason I post this is because a couple reviewer said they have used and working fine one was Kubota tractor and the other was just Kubota engine driving chipper. Have a bracket attached to generator with magnet epoxied to housing Wondering if that may cause interference? but it's reading steady just high. Only other place would be crank pully face and pick up not long enough.
I moved the pickup to about .09 but Haven't had a chance to see if improves reading.
