Differential won't stay locked
50shootr
B6100D, Honda 70 fourtrax STIHL MS 250
Nov 4, 2012
So. Dartmouth,Ma.
Hi.. Have a B6100D 950hrs.. I press the lock pedal when the wheels slip on snow both wheels engage but don't stay locked, the opposite wheel will now engage,if I reach down & push the pedal down with my hand same results.,any suggestions ? just an adjustment right ?
5,311
You understand that they only lock when pushing the pedal, let off the pedal and they unlock (spring loaded).
No there isn't really any adjustment to that set up, up is off down is on.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Not sure of your tractor set-up, but usually If you need the lock, you have to keep your foot on it. Normal practice is engage it when no power is going to axle, and once the wheels start turning you usually can take foot off, but not always. They usually disengage once you aren't playing power. Never engage it while any wheel is spinning or you will never have it again (until repaired).
2,219
So - when you push down on the lever - it stays down BUT the two tires still are not locked? Is there any "feeling" of engagement when you press it down?
On my BX - the lever has a spot that once you push it down, it goes the rest of the way as the wheels are spun a bit.
I would check the linkage first.
koja
BX25D
May 27, 2014
335
Fremont Mi.
On my bx when you press down on the pedal it takes a few for it to engage . You can feel the pedal go lower when it engages . When you let off the pedal it disengages .
50shootr
Nov 4, 2012
So. Dartmouth,Ma.
Thank You Gentleman for your replies... Thought I was doing something wrong,I pressed the pedal once the the wheels barely turned, added power and if I kept my foot on it was ok,love this tractor, live 1/4 mi from the main road and wasn't able to finish plowing because of something as simple as that!! Had a Ambulance out here didn't get stuck, but the oil truck got stuck yesterday and a big tow truck came out and winched it out all because I didn't know how to operate the differential lock !!
2,219
Just like everything else on one of these Orange beauties - there is always something that we can all learn ! If not for this forum - a lot of people would have many simple things NOT explained! I learn something about a Kubota tractor here almost everyday! :)
Lewis
b6000
Mar 2, 2009
19
Massachusetts
This is something that I have wondered about. Is it supposed to stay down? Mine disengages when I take my foot off the pedal and I guess that's the way it's supposed to work.
ShaunBlake
Dec 21, 2014
899
On the B-series anyway, there's a spring under the pedal. Lift your heel, the pedal pops back up, disengaging the lock.
Sort of inconvenient when using the foot throttle, but as you note, that's the way it's supposed to work.
5,311
Yes it's only supposed to engage while holding the pedal down. ;)
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
The clutch is your friend when needing diff lock. Foot throttle is nice but it's better to run the RPM's up to what you need and work the clutch. Trying to time one foot is harder than using both.
ShaunBlake
Dec 21, 2014
899
I'm "ass"uming this is offered for me. While I agree fully with your points, I have a very strong aversion to engaging a clutch when the RPMs are as high as I usually need when confronted with the need to lock the differential.
The best solution for my dilemma is to learn to work the hand throttle, the brakes, the dif. lock, and the FEL levers like Beethoven playing a sonata rather than like me playing chopsticks.:eek:
50shootr
Nov 4, 2012
So. Dartmouth,Ma.
Hi..Thanks for all the input,I worked as a marine mech & replaced many of those clutch dogs in outboard & stern drive gear cases which are in the Kubota differential lock so now I know how it works, this forum is great!, used to call Honda,Yamaha,Merc. Omc. etc. tech. when I was stuck on a customer job again being a mechanic this B6100D is a well made, reliable,robust Machine .
