Diesel prices???
bearskinner
Sep 1, 2014
926
241
N. Idaho
I filled up at Costco in town yesterday gas was $1.49 I saw diesel at $2.39 at a regular service station
andmel
L2850 / L3901 LB / G1800
Dec 17, 2014
50
concord, VA, USA
While we're talkin' diesel prices, why is it that diesel prices don't drop equally proportional to gasoline prices? Isn't diesel cheaper to make too (takes less refining than gas)? I'm not the sharpest crayon in the box but if I remember correctly, diesel used to be cheaper than gas when I was a kid.:confused:
7,191
The main difference in diesel cost from years past is Federal regulations for sulfur content. Use to be 500 ppm (parts per million) now 15. So now it cost more to refine.
Gotta have clean air or we are all going to die an early, miserable death!:confused:
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
Along those same lines, what's the deal with Kerosene? I can't find it any cheaper than $4.799.
The world has definitively turned upside down from when I was younger. Used to be gas, most expensive. Diesel, Cheaper. Kerosene, the cheapest.
I guess it boils down to supply and demand. In any case, it SUCKS!!
Ron
andmel
Dec 17, 2014
50
concord, VA, USA
Ron
I think you're right with the S&D approach to higher kero prices. We had a kero furnace for heat when I was a kid. As far as heating houses now, most folks have gone to natural gas (where available) or propane. I'm a wood burner myself.
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
You can go broke heating with propane here, and it doesn't get that cold. I just had my tank filled up with plans of limitless grilling as well as operating a small forge. Cost almost $500, and that was much cheaper than other options I shopped around due to a good size "new customer" discount that saved me about 30%. I remember steel being almost cheaper than wood for building things, now both are sky high and steel is ridiculous. Propane used to be cheap. And when I bought my truck, Diesel was at $1.69 a gallon. I remember because at ~20 mpg I used to harass my buddies getting 10 mpg near $3 a gallon on "regular" gas.
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Took the wife to Myanmar to have lunch today. Diesel 20.70 baht per liter. (I'm too lazy to do the conversions for you guys;)) Wish I could bring a tanker home to feed my tractor and truck!
8,830
Gas is back up to 2.16/ gallon, diesel is 2.58/ gallon
Grateful11
88
Piedmont, NC
They had 400 gallons of off-road diesel delivered to the farm about two weeks and it was $2.30/gallon delivered. He said it was the ultra low sulphur. He said he had some regular high sulfur fuel a few weeks before. He also had K-1 in one compartment and out of curiosity I asked how much it was and he said it was $3.25/gallon.
In our home our main source of heat is a 13SEER heat pump with a fossil fuel kit on it to use the oil furnace during defrost, no heat strips, and I have it set to cutoff the heat pump at 25 degrees and then run nothing but the oil furnace. I use a Honeywell 8000 series thermostat with an outdoor temp. sensor to control the heating system. We supplement the heat with an EPA certified Century woodburning insert.
Gasoline is $2.15-2.19 and Road Diesel is $2.69-2.92. Diesel is going up faster than gas around here.
Tomcat
Nov 19, 2014
557
Thailand
UP??? That's cheap don't you think, compared to recent prices?
I can remember "gas wars" when regular gas was 22.9!
8,830
Still better then what it was, but it's up 60 cents per gallon compared to what it was a month ago :rolleyes:
