I don't use my tractor in the winter do I put an additive to my fuel,the additive I bought says only to use it if you are operating it in winter.
If they are both for the same purpose.... then your simply overdosing it. Won't HURT it but...... won't double the help either.I have a question.
Is it OK to use more than 1 additive at a time Such as Peak anti gel and Diesel Stabil
That is an almost unanswerable question. All of these additives have different chemical compositions. So it depends on which ones and whether they interact. To find out search out the materials safety and data sheets on each, which are published online, and then find someone with a degree in industrial chemistry Some probably mix fine but others? If you stick with ones from the same company you might be able to find out from that company.I have a question.
