Deck Gearbox Question
Bruce Amacker
G2160 Diesel Lawnmower
Apr 4, 2019
Cleveland, Ohio
Yes, I searched and after reading many posts I think I have my answer but want to be sure.
RCK48R-21G gearbox leaking and empty. I have the manuals for this and I'm not sure why but the WSM says to refer to page PG-18 and the book stops at page PG-14. Grrr.
I want to verify this is the fill plug on top.
This bolt/plug on the side was missing, probably shook out and puked all the oil out. I assume it's a short 8x1.25 with a copper gasket, seal or something and just want to verify. It's an oil level hole plug, right?
Thank You!
Saxman
L3830 ZD21
Jun 19, 2010
154
Mt. Vernon, IL
Yes. The upper check plug.
I have a question since we are on gearboxes. I have a ZD326 and I’m going to change the oil in the gearbox. The manual states GL3 class oil 85W90 weight. GL3 is tough to find, GL4 and GL5 are everywhere. Dealer says GL5 is ok. Thoughts?
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
653
116
Rising Sun, MD
The larger hole on top is the fill hole. The upper side bolt you pointed out is the fill to line. If that box is dry... I'd pop the cover and inspect the bevel gears. The lower shaft seal under the pulley was the culprit that costs me a smidge more than $1000.00 ... yep a grand for the new gear box. My gears were trashed and metal shavings were in the bearings... The whole box assembly complete with the pulley ready to bolt on the deck was significantly cheaper than buying the parts and rebuilding it myself. Good luck... as it is dry for a reason... the lower seal is easy to replace once you pop the pulley... a little time and about $15 will save your box....
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
API GL-3 is just an older spec. An 80w-90 or 75w-90 GL-5 will work fine.
GL-4 would work too, but nowadays is harder to find and is used for manual transmissions, but that's beyond the scope of your question. :eek:
Saxman
L3830 ZD21
Jun 19, 2010
154
Mt. Vernon, IL
That was my thoughts, are there any bronze bushings inside the gearbox like in manual transmissions? I don’t think GL5 will hurt anything
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,239
1,022
Williamstown Ontario Canada
The last one I took apart only had ball bearings and a spacer to keep the one shaft's bearings apart.
Dave
whitetiger
Nov 20, 2011
2,955
1,404
Kansas City, KS
3,326
And the amount of EP additives (containing phosphorous) is sufficiently low so as to be backward compatible with earlier units that have "yellow metals". The advantage of the EP additive far outweighs the imagined insult to "yellow metals" in older units. (For EP to harm bronze/brass/copper it must be at much higher concentrations than found in GL5. BTW, I ran GL5 in my 9N Ford tranny for 15 years with absolutely no problems or leaks, despite all the old wives cries.)
This old wives tale is similar to someone arguing against using the latest grade of motor oil in their 8N Ford, insisting upon only non-det, straight-wt oil. The grades are all backward compatible.
