I went to start my L 3301 tractor, and my battery was dead. I heard some unusual noises but was unaware of what they were. I attempted to charge the battery. It would not charge. I attempted to start the tractor with 200 amp charging settings on my Charger, that also Failed. I replaced the battery, The tractor will now turn over, but it Sounds as if there is no fuel. As i pay more attention To the dash display, I start to see a multitude of Error codes Most appear to be electronic 12 V battery related.
I am not a mechanic, even though I am now pretending to be one. I believe my problem is lack of fuel, and I believe it is the fuel shut off solenoid. When I turn the ignition key on it makes a snapping sound.Thank you for any help you can give.
