D950 oil pump lifespan? (B7200 HST-D)
primerk5
Maryland
Has anyone ever had a failure with the oil pump on a d950 engine? I'm in the middle of rebuilding my engine due to a connecting rod bearing failure. My low oil pressure light did not come on when when you turned the key to the on position with the engine off so i figured there was probably a bad sensor or bulb. I never had time to check to see if that was the case as the engine was knocking and i didn't want to run it to much. (the tractor was given to me in this condition.)
I was just about to put the pump on and I got to wondering if it should be replaced. The WMS says nothing about inspecting it, so i'm not sure what to do. Just wondering what the general consensus is on failures seen. Per the hr meter my tractor has 1400 hrs on it. (that's if the hr meter is working which i'm not sure of yet either)
I'm leaning to using it as i'm pretty sure that everything appeared to be getting oil when i tore the engine down. Also if it helps the rod bearing that failed was the one closest to the front of the engine. All others appeared to be in good condition.
7,007
Me personally considering that it might have been starved for oil I would replace it and the oil sending unit and the bulb too!
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
I've never experienced any kind of oil pump failure.
That said, you had one oil starvation, you willing to risk it?
Replace it.
olthumpa
L275
May 25, 2011
1,501
Maine
In the early 1980's I had an oil pump fail on me with less than 500 hrs on the machine. They can and do fail. Like others have said, I would not risk all the money and time you have put into the rebuild on the condition of an unknown oil pump.
Just my two cents.:)
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
Hi
Some information attached on the D950 lubeoil system.
Suggest you have "system" issues. The issue may or may not be the pump.
Have you dismantled the pump, relief valve, strainer, blown out and proved all the oil routes.
Hope this helps
Let us know if you find anything.
Happy new year.
