D950 Issues
kubotaloverpp
jacobsen turfcat w/kubota motor
Aug 15, 2026
canada
Hello,
I bought an older jacobsen mower with a kubota d950.
I bought it non running.
I got around to trying to get it running, and I put a new battery in and tried cranking but my battery was undersized so i cheated and used starting fluid(I know...) and it popped off.
It ran fine, except for one small issue it smoked like a freight train. I ran it for 5 minutes and stopped it and and checked the oil and it was slightly overfilled. I drained it and it came out super sludgy, almost solid.
I put new 15w40 in went to check the coolant reservoir and it was empty. Filled it with water and started it and ran it for 30 minutes hoping it would clear up and it didn't.
I checked the coolant and my water was now black and murky.
I was wondering what my next steps should be? Should I take off head and check head/gasket or do a leak down or pressure test first?
Also what are the chances I get lucky and its just a gasket instead of needing a new head?
Also if I do buy a new head, is there something I should do to check if the rest of the engine is sound before investing the money?
Thanks In Advance Folks!!
11,184
First pull the injectors and look for water/moisture on the injector and in the cylinder.
I would also do a compression test before you pull the head because that will give you a ton of useful info to go off of.
You're chances of a blown head gasket are slim to none.
These engine are know for cracking the head on over heat.
Compression test will tell you what you need to check when you pull the head.
Since you've also used starting fluid you will need to check for rod damage on all the cylinders.
kubotaloverpp
Aug 15, 2026
canada
Thanks for the tips, quick question, based on the results of the compression what will it tell me?
Hopefully I didnt do too much damage with using ether.
11,184
The compression numbers tell you a lot.
If the numbers are all low then you're looking at major wear or major damage.
If only one cylinder is low, usually very low, then that would point to a cracked head.
If the cylinder is just low then damaged piston, damaged rings, damaged cylinder walls, or bent rod.
whitetiger
Nov 20, 2011
3,755
2,168
Kansas City, KS
You ran it for 5 minutes BEFORE you checked the engine oil and coolant levels.
You sprayed either into it to start it, then ran the engine for 5 minutes without any coolant.
What could be wrong with this engine? :unsure:
3,578
My thoughts exactly. :(
kubotaloverpp
Aug 15, 2026
canada
Thanks for your help, i will do that.
