I am in the process of repowering a farmall cub with a motor I pulled out of a f2100 mower. When it was in the mower it would smoke a lot of white when it was cold (my wife named it ol Smoky) It would misfire while it smoked and eventually clear up and run fine. This would take about five to ten minutes to get it cleared up. I pulled the exhaust manifold off and saw it was only the number two cylinder.
I sent the motor off to be rebuilt. It was bored, crank turned, valve job, and the head was magnafluxed for cracks. Nothing was done to the injector pump but I did buy new injectors.
I got everything buttoned up on it today. I started it today and the same smoke is coming out of the number two cylinder. It is on an engine stand with no coolant so I only ran it about 30 seconds to watch the oil pressure climb and make sure everything was ok.
I am at a loss as to what to check now. I am not familiar with the injector pump on this engine. Is that where I should go next? Any help would be appreciated.
