D-ring for the chassis front
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,119
3,381
The typical weight distribution for MFWD tractors is 65:35 towards the rear. The wheelbase of these tractors is about 65", and they weigh about 2200 lbs. The D_ring looks like it's 8" or so above the front axle centerline, and the tires are 24" OD. If we imagine the front tires to be (magically) superglued to the ground and the drive shafts frozen, we can compute the amount of pull needed to lift the rear wheels of the tractor by summing the torques (moments) about the tire contact point:
2200 * (.65 * 65") = (24/2 + 8 ) x PULL on chain
2200 * .65 * 65/20 = 4648 lbs.
Since the pull needed on the line is more than 2x the weight of the tractor, the tires will slip long before the tractor lifts the rear wheels, and the D-ring is completely safe. If you're paranoid, carry some heavy implement on the 3pt; it will definitely help the pull, since the rear wheels will do most of the work, anyway.
- Bart
And 4600 lbs is going to be far less than the resistance of a car sliding across a slick surface.
dkbswim
31
23
columbus ga
in regards to using it as a tie down
Anything 10k or more has to have 4 points of contact. IE , a chain & binder on each corner but if under 10k two is fine. 4 is better but 2 is acceptable. Disclaimer don't take this as legal advice please review laws that apply for you
look up CFR title 49 Chapter 3 Part 393.128 (b)
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
296
295
Amsterdam, NY
Get a "Recovery Stap" from HF instead of chain for pulling cars and other items out of jams. About $27 for a 9000 lb. strap. They have stretch to absorb the shock. Much less stress on car parts and the tractor. Make sure the D-ring is sized to accept the hook (ask me how I know, Duh). I've used mine a couple of times with great success. I don't use it for anything else though - every "tool" has its purpose - the right tool for the right job is part of being safe.
torch
Jun 10, 2016
2,750
975
Muskoka, Ont.
Be really,REALLY careful about pulling 'cars out of ditches' with a chain to the front of your tractor !!!
When (not if..) the chain breaks you might not even get to say 'Oh Sh.. '
I was thinking the same thing. I had that happen once (with the tow hook on the front of my truck). Now I'm a big fan of kinetic recovery ropes.
Edit: I see Bee-Positive beat me to it. <lol>
jyoutz
Jan 14, 2019
3,384
2,429
Edgewood, New Mexico
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,119
3,381
By damper, I assume you mean throwing an old moving blanket over the chain?
Yeah. Almost anything, really. Jacket, floor mats, or even a couple shackles. Of course there are the weighted pads made specifically for the task.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
190
74
Waterford, Maine
I was looking at pulling a car out of the ditch on my road last week, and realized there's no good place on my LX to hook a chain. I could use the draw bar in the rear, but with the 3pt snow blower attached that's not very accessible. So I thought a D-ring on the nose was in order.
I bought the D-ring and loop at the farm store. Didn't have a scrap of steel plate big enough to cover all 4 holes in the chassis, so I welded up some scraps of 2-1/2 x 1/4" bar stock, then welded the D-ring loop to that.
A quick shot of clearcoat to limit rust and voila. Attached with 4x 3/8" grade 8 bolts (I could have gone bigger but neglected to measure the chassis holes before I was at the store buying hardware).
5,175
- Bart
- Bart
"The wheelbase of these tractors is about 65", and they (MFWD tractors?) weigh about 2200 lbs."
Really?
MFWD tractors typically "weigh about 2200lbs"?
Downeaster
Oct 18, 2022
190
74
Waterford, Maine
I was really considering the D hook, but I have no welding equip. i thought about drilling
through the plate, so I checked the thickness, and it is way to thick and not worth the
effort. So I will just buy a couple of tie down instead.
3,666
Looks great man!
Joisey
Kubota L47 TLB
May 31, 2015
191
124
Wild, Wonderful West Virginia
Used to run chain through an old tire to absorb some of the energy
An old blanket will do the same thing. Drape it over the chain about mid point.
