Cut height for brush cutter
Flat6s
BX 25 D
Jun 14, 2018
Burlington Indiana
My pto shaft problem is now resolved. So my next issue is :
Is there a way to set the cut height for the 3 point hitch to lower to and stop. So what I mean is...I lower the three point hiitch and it does not stop. I have to guess how low it is each time,
Just does not seem right. The MMM has a cutting height knob, seems like the three point lowering lever should have one also .
Thank you
Joe
6,336
There is no way to set a three point for height on that model.
You would accomplish that with check chains set to the height that you want.
2,551
Thank you
Joe
There is no knob obviously - but there are simple ways to set a "stop" and have it adjustable too!
Called a limiter chain - cheap and very effective.
type in limiter chains in google - you'll see a couple of ways to set your cutter to a set height and have the adjust ability to raise and lower it as you wish.;)
here is a pdf :
http://www.ntractorclub.com/howtos/pdfs/Limiter-Chains.pdf
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
Thank you
Joe
Like Wolfman says, without position control, you will need limiter chains.
SDT
