Crankshaft Nut - Righty Tighty Lefty Loosey?
OlTrailDog
L345DT w/ loader backhoe
Dec 4, 2014
61
Bozeman, MT
I my searches I have seen nothing to indicate an L345DT crankshaft nut would be left handed. The only mention of thread direction was on a D1105E and it was right hand (CCW to loosen).
I've used a pneumatic 1/2" on the deep 46mm socket and a long breaker bar with liberal doses of PBlaster on the crankshaft nut. I can get what appears to be a little movement (unless the whole belt pulley is slipping) with a long breaker bar. But it seems like it is either getting tighter...or stripping the threads. Set up: Engine still on tractor (no access to flywheel) , in gear, brakes set, and chain vise around belt pulley. No access to fly wheel
Therefore, since the ramifications are rather expensive, to say the least, I thought I'd pause, take a deep breath, and ask about right hand/left hand just in case. What happens if I do strip the nut, i.e. new crank or can it be built up and re-threaded. How about cold chiseling to split the nut. Maybe torch it for a bit, &^%(*&&^%@#@!!!
Is it snowing where you live?
5,171
Yes, it's righty tightly lefty loosey!:D
If it's not coming off splitting the nut and replacing it with a new one would be a good choice! ;)
Split the nut, remove pieces, remove pulley, chase threads, reinstall.
OlTrailDog
Dec 4, 2014
61
Bozeman, MT
Thanks Wolfman. After some cold chiseling interspersed with an air chisel the nut finally started working loose about 3/4 the way through. It would loosen and I could take a turn with a pipe wrench until I felt too much resistance...chisel...loosen..turn...and so forth. It is now officially off. Hallelujah!
There was some cross threading evident. So chasing will be a necessity. Anyone have any idea on the die size? Measuring with vernier callipers it appears to be a 30mm shaft and I assuming 1.25 pitch.
Looks like Monday will be time to crack the case and check the timing marks.....fingers crossed....Oh please, please, please let that be the problem.
