I think maybe a few of you may have similar mowers, so here goes.
This one has the 42" deck with side discharge.
For its 25th birthday we sent it away to get a major overhaul but since it came back we have had nothing but trouble and the guy that repaired it is cocooning.
First day out, it went about 100 yards and burnt out a new bearing on the top of the shaft coming from the blade.
Second day out, it went about the same distance and wore all the teeth off the blade shaft and pulley on the left side.
Third day out, another 100 yards and done the same to the blade shaft and pulley on the right hand side and broke the belt.
The only time this has ever happened previously was when it hit some wire about 20 years ago.
He put new pulley brakes on the deck, which it hasn't had for at least the last 20 years.
There are no washers on either shaft except holding the blades. Everything seems to turn freely.
Don't want to be spending €75 every time we take the mower out and taking a week to cut the lawn.
Any ideas?
Thanks
Any ideas?
Thanks
