Cost trans rebuild
ferguson
L3130
Jan 19, 2022
327
135
w.v.
Make sure you remove and save all the very thin shims under the injection pump as you will need to reuse them as that is how the timing is set!
Any tricks to getting to the governor & throttle springs off / took bolts & nuts cover can pick it out a bit but not enough to get to springs dont want bend or brake them / going to change them any way Thanks
