cost to install quick attach loader LA525
Smf834
L2501dt
Nov 1, 2021
49
1a2b3c
What is the most economical way to switch from pin to quick attach bucket setup? I was reading the L2230A from Kubota.
If i have a pin on bucket with LA525, what is the easiest way for it to accept other implements such as stump bucket or pallet forks? Thank you.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,435
1,250
WestTn/NoMs
ATI makes a Tach-All for the LA525 for about $1,000.
If you can cut, fit and weld, you can buy the latch mechanisms and weld them to the ears you cut off your bucket.
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
293
East of Placerville Ca
Like potreeboy said get a ssqa and install it on the tractor. Then you can switch to ssqa implements with ease. You don't need to convert your bucket. You can unpin the ssqa to use the bucket but its a REAL PITA! You can buy a plate that can be welded on to your bucket to permanently convert it to ssqa. A local welding shop can do it for you if your not inclined to do it yourself.
B737
LX3310
Jun 9, 2019
2,024
2,197
New Jersey
check out Everything Attachments, they sell adapter plates that are made in Michigan and drop shipped, not sure which company they are from. They are very compact, keeping the bucket very close to its original position. The one I had for my BX only weighed about 50 pounds and was around $500 I think. It was the best money I ever spent on that machine. After I ordered, it arrived via fedex in under 4 days.
Smf834
L2501dt
Nov 1, 2021
49
1a2b3c
So to understand correctly, i need an adapter that goes on the end of the boon of the loader, and a metal plate that will be welded onto the bucket after the tabs are cut off?
For cost, the adapter for the loader side is about $1100, and the metal plate to the bucket is about 300-400? Does that sound right?
B737
LX3310
Jun 9, 2019
2,024
2,197
New Jersey
entirely up to you... When I converted my BX I sold the old pin on bucket for $200 and purchased a new SSQA bucket for $400. Buckets arent that expensive if you don't feel like DIY'ing. Just gotta find the right conversion adapter for your specific loader.
Orange man
Kubota L2501 LA525 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
162
WNY
The quick coupler from Kubota is only $461, no idea how long to get but might be worth wait
Matt Ellerbee
MX6000
Jun 27, 2019
1,680
1,887
Canton, Georgia
Here’s a few with a quick google search.
ranger danger
Jun 11, 2017
310
293
Close! The adapter plate you can get from Titan attachments for $135 (in the link below). A welding shop should charge you no more than $350 to weld it on.
I don't know the SSQA adapter price but its probably around $1100. The SSQA adapter is a pin on so no big deal to add to your front loader arms. Just unpin the bucket and use the same pins to instal the SSQA.
https://www.palletforks.com/dw/imag...res/Attachments/163200_02.jpg?sw=1001&sh=1000
Orange man
Jul 23, 2014
162
WNY
I am not sure why you would want to go aftermarket when the Kubota one is cheaper? L2216 $461.00
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple
Feb 10, 2019
87
68
WV
I went with ATI for my Ford 1720. I ordered it through Messicks. ATI built it for my loader. All I had to do was bolt it on. I also got the plate to weld to my bucket. Very nice setup. It was about $900. I also order the WR Long 3rd valve kit. I have a grapple, pallet forks and my bucket. Very happy with it.
Ron
Smf834
L2501dt
Nov 1, 2021
49
1a2b3c
If i go with the Titan mounting plate for the bucket, what is the proper thickness? 1/2 or 3/8"? And are those plates universal to any bucket? Do they just center it? What about the angle of the plate to the back of the bucket? Thanks for sharing your way of doing things.
Smf834
L2501dt
Nov 1, 2021
49
1a2b3c
Will definitely call the sales department tomorrow and see if it's feasible. If it is within a 1k for the whole project and doesn't require no more than taking off the bucket and put it on my pickup and have a weld shop do the rest, I think i can handle that:)
ranger danger
Jun 11, 2017
310
293
Go with the 3/8". Your loaders capacity is to low for anything heavier. In fact, if they had a 1/4", it would still be good. Yes universal. When I installed the last one, I just centered it on the bucket. An inch or 2 up or down just won't make enough difference to matter. The angle of the plate changes with the hydraulics of your loader so no differance.
ranger danger
Jun 11, 2017
310
293
If you ever plan on getting/ using a grapple or tree puller or any other fel tool that needs its own hydraulic connection, now is the time to instal a 3rd function kit as well as the SSQA.
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
I converted my LA504 loader using a factory Kubota SSQA adaptor for the loader side. I bought a Everything Attachments weld on plate for the bucket. These worked well for me.
