I thought I would ask those with experience operating the front mounted snow blowers what the best operational sequence was.
I am new to the front mounted units previously using an Allied 72 inch rear mounted unit, which in comparison to the Kubota unit was battleship quality.
I ran the PTO all the time and had it set to auto disconnect when lifted near bind height.
With the front unit, is there a bind height. When blowing do you engage the unit and then move back and forward leaving the unit running when lifted or do you slow the PTO speed, disengage the PTO lift the blower and back up. I ask this because I have a very wide area and start by doing a couple of long runs, then go back and forth, currently I am slowing, disconnecting backing up and re-engaging - but that is taking way longer than my previous rear mounted which mostly ran when only slightly lifted.
So, what are the thought of the experienced operators?
Hoping I can speed this process up a bit, maybe too cautious and now after the PTO shaft fiasco a bit gun shy.
