Cold Weather Starting
mcmxi
6,748
NW Montana
Do you run #2 diesel at those temps? I run #1 and Stanadyne. I put some #2 in pickle jars with different amounts of Power Service winter/white bottle and they were all as cloudy as straight #2 at around +5 F. I assume Stanadyne is better, but have never tested.
I only run #2 and Stanadyne in the tractors and generator without any issues.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
It has been quite cold in SE IN these past couple of days, and I have needed to use both of my smallest Kubota tractors, both of which are set up for snow removal in winter months, for such duties.
The B1750HSD, bought new in 1994, has never failed to start, now or previously, though it has sometimes protested. The 2018 B3350 has also never failed to start, though it protests more so than the 1993/4 1750. I have never needed hair dryers, etc., but do keep an old one nearby.
FWIW: I NEVER use ether but do keep good, well-charged batteries. I also add anti-gel additives to fuel tanks in the fall months such that the anti-gel is well into filters, pumps, etc., before cold weather sets in. On occasion, if conditions indicate, I plug maintainers onto batteries 12+ hours before anticipated starting times.
Both tractors are mechanically injected though there are about 25 years between build dates.
I have started the B1750 (without ether or hair dryer) well below 0 but doubt that the 25 year newer B3350 would do so. Both tractors will start on 1 or 2 cylinders after long periods of glow plug warming but the 3 cylinder 1750 is much more likely to pick up and run without giving up, than is the 3350. Yesterday, it took 3 efforts to get the 3350 running on all cylinders at 0 ambient, whereas the nearly 30 year old 1750 required only one such effort. Fortunately, the battery in the 3350 had sufficient capacity to recrank the 3350 twice. Rather annoying for nearly 30 years of progress.
Despite the "lifetime emissions" warranty on my 2018 B3350, and no emissions issues after the reformer, DPF, etc., was replaced upon last trip to the dealer, I may well replace it with the forthcoming LX4020 with electronic FI.
That said, I am not convinced that either my M9960 or L6060 (both not set up for snow removal and rarely if ever started outside of mowing season) would have started yesterday despite electronic FI because, both are showing signs of needing battery replacement due to pre-sale negligence.
Interested to hear similar such cold weather starting experiences.
Older gas engines in general start easier in general in cold weather because they are more loose in the cylinders from wear. Probably not true in diesel? I have the 2610 purchased on purpose because it did not have the 3310 emissions stuff. I sometimes go thru a revving up process back and forth from low to high thinking I am helping clean out the soot from engine. Maybe this is a waste of time. I know that my pickups will run crappy if they are run low rpm like locally and not taken out for an "Italian tune-up" run at high rpm for some time.
nbryan
Jan 3, 2019
1,253
787
Hadashville, Manitoba, Canada
I live in Northern Canada, average winter temp is -20 c ( and quite often - 40 or more) I install a
block heater and changed the oil to a quality synthetic winter grade as soon as I got it. Two years and no problem starting yet ( I do put summer grade back in for the summer ) Never use any kind of starting fluids!!
What's the make and viscosity rating of your winter oil? I am using 5w-40 Rotella T6 year round here in SE Manitoba. No need to change to summer weight oil at all, and does start more readily in the cold compared to the 10W-30 semi-synth diesel oil I was using before n this machine.
I don't bother plugging the block heater in unles it's 10C or less. Starts esily without block heater, with 10 sec glow, in -10C.
