I am about to put my L3430 back together after overhauling the motor and replacing the clutch, pressure plate and release bearing. The WSM says to grease the splines on the clutch but doesn't specify the grease or state a warning on over use of grease getting on the clutch disk. The splines that engage the clutch and the flywheel hub were dry and rusty when I split the tractor, doesn't look like they were greased at the factory. I'm thinking if I use anything it will be a very thin swipe of never seize. What are the experts doing when servicing Kubota clutches?
Thanks
Thanks
