Clutch pedal jumping
dew
l200 kubota,bushog,rear scraper blade and carryall.
Nov 28, 2013
22
elizabethtown,ky. usa
I have a L200. I've noticed the clutch pedal jumps up and down about 5/16" when in neutral or in gear. Is this something I should be concerned about? Clutch works fine.
2,192
if you lay your foot on the clutch pedal lightly - do you feel it pulsating? Or is this just a spring lose that keeps tension on the pedal itself?
Another thought guess would be a throw out bearing is about to go!
dew
Nov 28, 2013
22
I don't feel it under my foot. Installed new springs on brake and clutch pedal last year. So how can I check throwout bearing?
2,192
IF it is not present when a small amount of pressure is applied - I would not think it is a throw out bearing. I would think the bearing would give you a tell tale sign with light pressure on the pedal.
Does the pedal move "faster" with an increase in RPM's? or is it constant with engine vibration?
Have you checked engine mounts?
