roundrockcrawler
Kubota L-3400 Howse Rotary Cutter Bushhog Finish mower Du Bob Chisel Plow
I have a 2004 L-3400 390 hrs four wheel drive and loader, with standard 8 speed trans, I also have a two wheel drive 2005 L-3400 with 360 hrs, the clutch on my 04 has to be fully pressed to the floor for a good clean shift through gears or from forward to reverse, my 05 works cleanly from 1/2 to 3/4 from floor, I would like the 04 to work the same. Can any one tell me how much to adjust the linkage to accomplish this, or should I leave it alone. I have no clutch slippage in either machine, just would like to keep up with the clutch wear adjustments on my loader if needed..Thx
