Donystoy
I have a new LX2610 with a front mount LX2963 blower. The joystick control operates the chute rotate which utilizes the same operation that would be used for the loader bucket curl operation. The rotate left operates fine but for the rotate right I have to go past the R1 position and snap the lever over to the R2 position. In the R1 position I only hear a slight hydraulic noise. Manual says R1 is high flow and R2 is low flow. The dealer tells me that this is the normal operation for the snowblower and has been that way for 20 years. He must mean that they have had the two-position right operation that long. I removed the loader immediately after purchasing so I do not know if it operates correctly. Anyone with a similar set up? My first thought was that something went wrong when they installed the third function stick.
