Changing Grease Type Bx 2370
bluelight16
BX2370
Sep 18, 2022
14
I am goimg to which from a multi purpose cheap grease to Lucas red N tacky on my loader and mower is there any problems mixing the two greases until I push out all the old grease, comments please Thanks.
3,166
No.
4,118
I would remove each pin and meticulously clean the pin and the bore that the pin resides in, and then reinstall the pins and grease them with the new grease. Be careful to wipe any excess from the tractor with a clean soft cotton cloth so you don't scratch the finish. For the cleaning solution, I would suggest that you use a mild cleaner such as Dawn dishwashing liquid and warm water, so it also doesn't harm the fine finish that Kubota puts on every tractor that they manufacture. I would also suggest that you use Meguires paste wax to keep that high luster on the finish. These details will ensure that when you are ready to upgrade or sell your tractor it will bring a premium return on your investment dollars.
4,223
Don't sweat it.
Just use grease often. Type doesn't matter in most circumstances.
Grease is a highly debated topic here, but you're probably making an improvement going to Red & Tacky.
