Chain Carrier Build
freudianfloyd
Kubota MX6000, Massey Ferguson 150, Farmall B, John Deere 410J TC
Sep 30, 2024
29
46
I know most people seem to have a front loader but since I have a bigger loader I opted not to get one on my MX6000. Up until today, I just had the threaded holes where the loader mounts on, plugged to keep dirt out. Well looking at it the other day, I realized that those holes are perfect for mounting other things on. One thing I have been needing is somewhere to store a logging chain. This weekend, I took care of that.
Measuring out the best I could, I drew up a mounting plate, and then found some scrap materials to make the chain holder out of.
I found some 6" steel pipe (wish I went bigger), 1/4" plate, and some 2x2 steel tubing.
I then had a buddy cut the mounting plate and bottom plug for the pipe out on the plasma table at work. And I used the bandsaw to cut the pipe and put a taper on it so the chain can be removed and installed easier without risking hitting the side of the tractor hood.
Then after figuring out exactly where I wanted to mount it on the plate, I got set up welding it. I left a notch cut in the bottom plate to let water run out of needed. Also, not my best welds so dont pick them apart too much, I had a 4 year old in the shop with me and he wouldn't stop causing trouble while I was welding.
And then gave it a coat of the darkest Grey enamel I could find (still not dark enough). I thought about painting it orange, but figured Kubota would've made it grey where it is mounted so I figured i would do the same.
And here it is with 16' of 3/8" logging chain. Again, I wish I went a bit bigger. Maybe on the other side I will add another one. 10287.jpg
The most expensive part of this whole project were the 4 mounting bolts. They were $10 each. The metal was free and the paint was $9 for the can.
Even if i dont use it for a chain, it can still hold tools or whatever else I need, and this tractor as you all know has very little storage places. 10282.jpg
Reactions: 9 users
5,577
Very nice sir!
I feel your pain about those bolts too.....I recently made a hydraulic SSQA actuator and 2 of the bigger metric bolts were something like 8 bucks each:eek:
The drain hole was a good idea as well.(y)(y)
Well done(y)(y)
freudianfloyd
Sep 30, 2024
29
46
Very nice sir!
Well done(y)(y)
Thank you
Yooper
3901 LA525
May 31, 2015
1,751
929
NE Wisconsin
Excellent work! BTW, your welds are not going to hurt anybody’s eyes.👍
JustJim
BX2380
Apr 9, 2026
11
24
Illinois
Very nice work! I like the design. I found that Rustoleum Gloss Charcoal Gray is the closest match I could find for the frame color.
Jim
freudianfloyd
Sep 30, 2024
29
46
Jim
Thank you. I was looking for charcoal gray but the darkest they had was "dark gray".
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,217
1,111
Amsterdam, NY
I like it, looks clean and not cobbed.
I'll have to use your idea to mount a couple smaller tubes to my ballast box to carry shovels and the like.
