Greetings
Trying to install a new fuel filter element on a B7100. This is the sediment bowl type with a replaceable paper element.
The new Kubota element appears to be too tall. Started off with the element in the bowl/canister. With the element bottomed out in the filter canister there was at least a 1/8" gap between the removable retaining ring and the threads on the fixed filter base.
Next I took the element out of the bowl and forced the filter upwards and seated it on the fitting in the filter base. Then I installed the bowl over the element. This reduced the gap. By forcing the filter canister/bowl up with one hand I can get the retaining ring to just touch the threaded base but not close enough to engage the threads.
I'm forcing the assembly up hard enough to crush/distort the paper element. The element that I removed appeared to be distorted the same way.
In the articles section there is a section on fuel filters. The author said:
" I have seen Kubota fuel filters jammed so hard into the sediment bowls that the filter breaks apart trying to remove them! Under the filter will be a small spring. Make sure it’s replaced when reinstalling the new filter."
This sediment bowl has a metal plate in the bottom but no spring that I can see or feel. Could this be part of the problem?
My frustration meter is nearly pegged and I'm about to take a pry bar to the sediment bowl to force it up. Rather than breaking the bowl or crushing the filter element, I could use some help before I go Neanderthal on this thing.
Thanks in advance
Jim
Thanks in advance
Jim
