When I push in the clutch on the L225, the engine will slow down a little. The shop manual does not mention grease, but the parts list shows a grease fitting on the side of the clutch release hub. When I look through the inspection port on the right side of the clutch housing, I don't see any fitting. (Unfortunately, the front end loader support also makes it difficult.)
If it had a grease fitting, is it lube the bearing, or just for the shaft going through the release hub.
right click on the attached picture - What is the deal with the angle between the bearing and the clutch assembly? This does not look correct. If that is a ball bearing, I have thought about just squirting some lube in there (keeping it off of the clutch disk of course.)
Any help would be appreciated.
Frank
Frank
