Yes, I wiggled and held the levers for all the hydro on all ....the BH and the FEL , the 3PH ....Did you hold the levers till the buckets settle to the ground or the transport pin?
If all else fails, you can loosen the hose connector at the cylinder (or at the disconnect maybe) to relieve pressure that may be preventing the separation of quick connect. If this doesn't work...something may be physically wrong with the disconnect...preventing separation.Yes, I wiggled and held the levers for all the hydro on all ....the BH and the FEL , the 3PH ....
the other BH connectors came apart very easy with a little push/lift the knurled sleeve and they pop off. the blue connector will not .....
I will try that thank yoiuIf all else fails, you can loosen the hose connector at the cylinder (or at the disconnect maybe) to relieve pressure that may be preventing the separation of quick connect. If this doesn't work...something may be physically wrong with the disconnect...preventing separation.
One step at a time...
