Can "NOT" remove the "blue) flat face connector on the backhoe
Tigercub
bx23s
Dec 6, 2020
24
Ontario
....I shut the tractor off, wiggle all the levers, joysticks etc to relieve pressure and am able to remove the other connectors but NOT the "Blue" connector on the BH......am I forgetting something?
lynnmor
B2601-1
May 3, 2021
1,769
1,577
Red Lion
Did you hold the levers till the buckets settle to the ground or the transport pin?
Tigercub
bx23s
Dec 6, 2020
24
Ontario
Yes, I wiggled and held the levers for all the hydro on all ....the BH and the FEL , the 3PH ....
the other BH connectors came apart very easy with a little push/lift the knurled sleeve and they pop off. the blue connector will not .....
3,379
If all else fails, you can loosen the hose connector at the cylinder (or at the disconnect maybe) to relieve pressure that may be preventing the separation of quick connect. If this doesn't work...something may be physically wrong with the disconnect...preventing separation.
One step at a time...
Tigercub
bx23s
Dec 6, 2020
24
Ontario
I will try that thank yoiu
Tigercub
bx23s
Dec 6, 2020
24
Ontario
ok.....huge embarrassment here. On removing the "blue" flat face connector? I was pulling on the knurled sleave insted of pushing on it....it came apart easy ......sorry all . i'm a newbie and had never removed the BH before to experience the disconnect procedure.
