I've been lurking here watching this post and from all the great info here, I checked my pressure and was shocked to find that mine was only about 1550. DOH!
Some history............
I bought my '05 BX2230 with a FEL and 60" mower deck about a month ago with only 500 hours on it and there were hardly any scratches on the thing. I found the bucket curl and FEL lift capacity to be somewhat weak and looking at the OEM capacities, felt it should be able to do more. Probably explained why I found it in such good condition. I began my search here for answers. Good thing I did! I went to a distributer near me that sells Parker Hannifin products and purchased a 3000 psi hydraulic guage. They even mated it to a 3/8 npt SAE Female Hydraulic quick disconnect all for about $45. As soon as I got it home I grabbed the keys for the 'Bota, disconnected the top line for the FEL and popped on the gauge to the male connector. I fired her up, let it warm up and increased the throttle to just a hair under max. Pushed the joystick forward and read the gauge. About
1550 PSI. Shut her down, removed the Plug holding in the relief valve spring, added a quantity of 7 shims made from .1mm shim stock for a total of .7mm. Replaced the spring, shim, plug. I then fired her back up and read the gauge again. I now have about
1950 PSI. Ready to try her out with new muscles!
VERY IMPORTANT NOTE: Place the shims so they are between the spring and the plug so they go into the recess of the plug and NOT up into the housing. This will allow you to remove them more easily rather than fishing for them up in the housing!
