BX2816 Electric Chute Rotator
BX23-S,57 A-C D-14,
6,323
hmm, '3ag' style switches, have 2-300 of them in basement.
FYI those are rated in AC volts and current ! 125v, 5 amp. Check the datasheet for the DC rating !!! Switches and relays designed for DC power are made with different materials for the contacts.
Now IF you're only drawing ,say 1 amp, they may last BUT aren't the proper switch and will 'burn out' (think distributor points arcing...)
SnowDoc
BX1880
Jan 17, 2024
Ontario, Canada
The Omron SS-5-F is rated at 5 amps @ 30VDC. In theory it should last a very long time if the solenoid is only drawing 1.5 amps @ 13.5 Volts.
BX23-S,57 A-C D-14,
6,323
that's good intel... only saw the AC ratings on the switch in the picture. with two cutup toes going into basement would have been 'interesting'....BUT I do know where the boxes of switches are.....
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
A seat motor worked on the Pronovost blower I used for a few years on the L3200. The larger gray box below the window is for the relays. The means of rotating the chute (cable wrapped around the chute) was factory. I only modified the shaft to accept the gear motor. A trailer "Flat Four" connector was used for the hookup.
doghousebob
Kubota B1700, LA loader, B2550 Blower etc.
Nov 23, 2020
Mono, ON
Hey SnowDoc, Thanks for the brilliant solution. Used your guide on my older B2550B blower with great success! Couple of pesky mods with the motor mounting plate, but worked beautifully. Cheers.
