We recently switched out a BX2750D Snowblower from a BX2370 to a BX1850. Everything mounted up perfect except the Mid PTO shaft. The shaft from the 2370 seems to be just a bit too long to work properly on the BX1850. We were able to get it to fit by moving the quick hitch shaft forward, but i don’t believe there isn’t much clearance to run it properly. Is there a different shaft that will work on the 1850 with the BX2750D snowblower? I have listed the model numbers I am using below for reference:
Tractor
Model: BX1850TV54
Blower
Model: BX2750D
Quick Hitch
Model: BX2751
Mid PTO shaft that was used on the BX2370 is marked: 07061, but I don't think thats a part number.
Tractor
Model: BX1850TV54
Blower
Model: BX2750D
Quick Hitch
Model: BX2751
