BX2680 engine speed not constant
rjacknew
St. Louis
when i engage the pto the rpm's reduce from 2500-3000 to 1500 without moving the throttle lever. i have to hold the throttle lever to keep rpm's constant.
any suggestions?
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Has your throttle lever become easier to move? The nut at the bottom of your throttle lever is likely loose. Take the battery cover off and tighten it.
2,747
any suggestions?
Most of us drop the RPM down to about the lowest point....engage the pto and then ramp it back up to cutting speed.
Maybe on the new machines, the pto engagement drops the rpm and then goes back to "normal?" but that would be a new one on me.
If you are engaging the pto and the engine speed DROPS.....and does NOT come BACK up......something is wrong and you need to see your dealer!
