O Orange dew New member Equipment BX 2670 Nov 15, 2021 6 0 3 Crawfordville Fl Dec 24, 2021 #1 Anybody pull old stuck cam on height adjustment knob?
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,196 1,883 113 Mid, South, USA Dec 24, 2021 #2 not sure what you are saying there. if it's stuck, take the deck out and find out why. There's a cam up underneath. Is the cam boss stuck in the frame? Detent plate broken off and jammed? Lift arm tab bent/broken?
i7win7 Well-known member Equipment BX2370, B2650 grapple, tree puller, trailer mover, 3 point hoist, mower, tiller Feb 21, 2020 3,379 3,981 113 Central, IL Dec 24, 2021 #3 See your a new member, if tractor is new to you, mower deck needs to be fully raised before deck height knob can be turned. Reactions: 1 user
O Orange dew New member Equipment BX 2670 Nov 15, 2021 6 0 3 Crawfordville Fl Dec 25, 2021 #4 i7win7 said: See your a new member, if tractor is new to you, mower deck needs to be fully raised before deck height knob can be turned. Click to expand... That seams to be the general consensus both those coments were pearls of wisdom Reactions: 1 user
