BX2670 3 point disconnect
cigarman
Ontario
Hello
I'm looking to disconnect the landpride cutter on my BX2670 from the 3 point hitch for the first time ever.
Last piece of the puzzle (I think) is the PTO - I've attached a couple of pics. Can anyone advise on how this disconnects/works? Any guidance or utube video would be very much appreciated.
thanks guys.
cheers
4,364
The shaft collar the one that slips on to the PTO.. pull the ring back as in its forward position it looks the shaft to the PTO. it may be a bit tight but wiggle it back toward the tiller the ring Im talking about and when it slips back it should slip off the PTO shaft
2,417
The collar will be under the gray shield with the warning sticker in your pictures
About in line with the orange part of the sticker
Some pull, some twist some have a pin
All are hard to get to
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
Lovells, Mi
There is an amazing amount of tractor information on YouTube and sometimes a video is worth more than a half a dozen descriptions of what to do. This one may or may not help, but if you do a search on YouTube you might find one that better matches your equipment.
https://www.youtube.com/watch?v=3sbk6ONJvMI
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
Don't know how to post links to u tube but,, search for how to get pto off, by mike wiles. Perfect explanation and pictures.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Cigarman,
Off subject a bit but I noticed in your first picture that it appears to me
that the weld is broke on the right hand turn buckle that faces to the
rear you need to get welded back together. It's the outside end where
it's welded to the nut on the rod if what I think I see is correct. Not a
difficult job to do or have done just need to squeeze it back together
maybe a couple whacks with a BFH to relieve the stress then weld it back
together.
Practice makes hooking and unhooking the pto shaft easier and in my experience if the slip collar isn't moved back and forth once in a while
they can get pretty sticky and hard to unhook. Lots of dust and dirt is
what causes that problem so maybe blowing the dirt out of it with an air
pistol once in a while will help keep it from becoming to packed with debris
to be able to move.
Al
cigarman
Ontario
Thanks guys - great information.
I'm embarrassed to say I didn't find the Mike Wiles video BEFORE I posted the question. Very helpful.
(and yes tiredguy - it is a broken weld - covered by dealer warranty and a replacement has been mailed / compliments on the sharp eye for details!)
Thanks again to all
