Bx2660 snowblower size
Bearcatrp
Mar 28, 2023
1,002
634
Minnesota
You want a minimum of width of your tractor. 3 point or front blower? Just bought a rear 3 point myself. My 1880 is 4 feet wide. My blower is 51 inches wide. Think these are made a few inches wider that the tractor it would normally go on. If you’re going larger, have to consider the weight. Am using a quick attach so my blower stick out back pretty good. So consider maneuverability of the blower too.
Bee-Positive
Nov 16, 2022
435
415
Amsterdam, NY
You can find the manual on https://kubotabooks.com/homepage/
Page G-46 & G-47 has the limitations for your BX.
It doesn't have a rear blower listed but I'd stick with 350 lbs. max front or back. If you're using a rear quick hitch you will want to subtract that weight from the total. For example: 350 total - 50 QH = 300 blower weight. As Bear said above a 51" width or there about fits pretty nice for the BX.
Note: the weight for the rear mount mower and disk harrow is less because they stick out farther and put more leverage on the 3 pt. like a long crow bar prying up and down. That's my opinion anyways.
