should be somewhat similar across the line, straight forward, messicks parts diagram will help you. I am no expert and his photo is from BX2350. Remove two screws exposed on top once you pop the hood, remove throttle and cruise stick knobs, the intake screen, steering wheel, unplug wiring harnesses. it will lift right off, and you'll have easy access to pop the dash display out.
