bx25 won't turn over, timing relay buzzing
dcortez
bx25
Apr 16, 2012
BX25 won't turn over. Sometimes the glow plugs seem to go other times nothing. Timing relay will sometimes make a brrrrrrrrrrrrrrrrr sound.
Anything I can check before I jump into parts changer mode?
Battery and ignition switch are fairly new.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
"won't turn over".
Have you at least load tested your battery?
Pawnee
L2501
Jul 1, 2021
350
299
Ontario Canada
^ Good idea.
Or jump it from something that starts well.
The last BX25 took over a week to get figured out. Here.
At least read Henros post #36 in that thread, it's technical poetry.
6,282
Battery or battery cables or connections, 90% of the time its bad ground connections!
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
Fairly new is relative. Check battery voltage. Monitor it while trying to start. It should be at least 12.6 before trying to start and hold above 10 while trying to start. Remove cables from battery. Clean battery terminals and connectors. Inspect cables for corrosion where they enter the terminals. Reconnect battery and tighten cables securely. If you can move them they're not tight. Follow ground lead to frame. Clean, inspect, and tighten.
