BX25 top and tilt
5,575
Decide on if you want the DPOCV (Dual Pilot Operated Check Valve) on it/them RIGHT F"ing NOW!!!!
They are a bitch to try and install after the fact......Trust me.......;);)
I would get them to prevent the dreaded "leak down".....
6,879
@MtnViewRanch is a member here who seems to get universally positive reviews on his kits, but I have no direct experience.
I have a dealer installed top/tilt. Could have saved some money going a different route, but it’s too useful to have any regrets. If you do much blade work, highly recommend.
MtnViewRanch
917
382
Lakeside Ca.
You asked this last Thursday. :unsure:
Try the following if you want more than one recommendation.
I also recommend going with the factory rear remotes for a cleaner look.
You will need check valves though, if you use the Kubota rear remotes.
Fit Rite Hydraulics
WR long
Summit Hydraulics.
