Bx25 hydraulic pressure loss
Robert 66
Bx25
Oct 9, 2026
OH
I had a blown line and replaced it. Refilled fluid but now I have 0 hydraulic pressure. Could it be a vapor lock?
I've checked filter, screen and anything I could think of.
11,276
What Implements are on / or what implements is the tractor setup to have IE: loader, backhoe?
11,276
Well thanks for the super informative answer??? :rolleyes:
You know we don't charge by the word here! 😜
So either your tractor has none of the implements or none of them attached? :unsure:
If you it's not ever been equipped with them, your saying you have no Power steering and no three point use right?
Please use more then one word to reply. ;)
11,276
This is why I was needing more information:
#1 issue with these when this happens is that the BH loop is not allowing flow.
Remove coupling (#150), put 190 into a bucket, hold it into the buckett and start the tractor, shut it off if you get flow and report back.
11,276
If you have also have no power steering, then it's likely you have a pump issue or a pump drive issue.
Can you get the tractor to move?
In other word have you also lost drive?
If you have, then you very likely have lost a connection from the engine to the HST.
1791603934053.png the tractor?
