bx24 won't turn over but....
jayro1028
bx24
May 24, 2015
saugerties NY
I jumped the starter and it fires up but when I get on the tractor it's fine but even if I put the parking break on I can't take pressure off the seat or it shuts down. Also while running I swiveled the seat to the hoe position (still running) then I swivel the seat back to drive position and as the gray seat safety switch is pressed it kills the engine. Scratching my head here? I've had the tractor 50hrs now and never any issues. I've tried the pto lever trick the HST pedal trick and no luck
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
The bx25 has three safety switches.
One on pto and one on hst pedal and the seat.
The pto and hst need to be in the closed circuit position for things to work.
Bottom of diagram.
You will have to use a meter and see if they are making contact.
Check wires as well.
Mice chewing wires?
I also have an operators presence control box.
That may be a problem.
Hope the bx24 wires are similar.
Ray
